No signal to monitor, though monitor works on another computer
smaj210
Friday March 15, 2013
Mar 15, 2013 at 09:50 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Mar 15, 2013 at 11:28 AM
- No signal to monitor, though monitor works on another computer
- Lenovo monitor not turning on ✓ - Monitor Forum
- Monitor zoomed in - Guide
5 responses
Mar 15, 2013 at 10:05 AM
Check your RAM. Refer to your motherboard manual to make sure that the
RAM you are using now meets your new motherboard's RAM requirements.
smaj210
Mar 15, 2013 at 10:07 AM
the ram does meet the requirements, and the mother board is the same make as the one previously in the computer.
i have taken out the ram and also tried one ata time but still no joy
Mar 15, 2013 at 10:12 AM
Can you hear the beeps if you Switch on without having a RAM placed in the motherboard ?
smaj210
Mar 15, 2013 at 10:13 AM
yes i got three beeps with no ram in the machine
Mar 15, 2013 at 10:16 AM
Have you tried the Onboard VGA ?
Let me know your motherboard brand name and complete model number. Also the RAM details.
smaj210
Mar 15, 2013 at 10:18 AM
yes have tried the on board vga, also tried another vga that works.
motherboard is a
asrock n68c-cs fx
like this
http://www.ebay.co.uk/itm/360566354147?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2648
ram is
elixir pc2 1gb ddr2 240 pin
motherboard is a
asrock n68c-cs fx
like this
ram is
Mar 15, 2013 at 10:24 AM
Let me know more information about the RAM. Example 200MHz DDR2_400
Ask a question
smaj210
Mar 15, 2013 at 10:27 AM
the only numbers on it are
pc2-6400u-555-12.e1. 1gb.2rx8.800
1gb ddr2 240 pin 128mx64 pc2-6
cant find anything with mhz on it though
Make sure you have inserted the RAM properly. If the problem still exists then
Turn off your PC and remove the power chord --> Open the cabinet --> Remove the CMOS battery for 15-30 minutes and then put it back properly. Now plug the power cord back in and switch ON your PC.
Click on the below hyperlink "CMOS Battery" if you don't have any idea about the CMOS battery
CMOS Battery
If the problem still exist, click on the below link and follow the instructions in "Hardware Reset".
https://ccm.net/faq/1192-lost-bios-password-resetting-the-bios
If the problem still exits then let me know if a single beep can be heard when you switch on your PC.
CMOS Battery
