Monitor Problem
sampath kumar
Monday July 8, 2013
Jul 8, 2013 at 11:36 PM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Jul 11, 2013 at 07:19 AM
- Monitor Problem
- Monitor zoomed in - Guide
- Power saving mode monitor - Guide
Jul 9, 2013 at 05:32 AM
1) When you switch ON your computer, start tapping the "F8" key to get
"Windows Advanced Options"( if boot menu appears, press "Esc" key and keep
tapping the F8 key)
2) Select the option "Enable VGA Mode".
[If you are using Windows 7, then select the option "Enable low-resolution
video"].
If the problem still exists then follow the Step 1 and this time select the option
"Safe Mode". When the desktop appears, undo the changes that you have made.
tapping the F8 key)
video"].
actually my desktop is not getting open.... after booting a black screen appears and it doesnt goes off.. on screen (HZ?) appears....
If you keep tapping the F8 key correctly then you should be getting the Windows advanced options and then you need to follow the above given instructions.
