HELP AspireOne d270, completely no power
jcabero47 Posts 4 Registration date Monday July 27, 2015 Status Member Last seen July 28, 2015 - Jul 27, 2015 at 11:19 PM
Computertech Posts 3569 Registration date Friday February 6, 2015 Status Moderator Last seen July 18, 2016 - Jul 28, 2015 at 05:17 AM
acer aspireone laptop won't turn on at all ( no LED turning on )
Computertech Posts 3569 Registration date Friday February 6, 2015 Status Moderator Last seen July 18, 2016 892
Jul 28, 2015 at 01:44 AM
Try with external adapter only.. or try to use battery to power on..
Are you sure your battery and adapter is good!
If yes then your laptop dead!
Jul 28, 2015 at 03:21 AM
battery and power adapter is good, but a glimmer of hope is somehow at hand because the unit when plugged in is heating up a little bit, it shows that something is still working inside.
May be the processor overheating?
But atleast you got some output in the screen and LED will glow but in your case nothing happend!
