Sound device problem
raj - 11 Jul 2009 à 00:45
 Blocked Profile - 11 Jul 2009 à 06:10
Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly.
\/ can you solve this matter . i need a free softwear of sound device.
11 Jul 2009 à 06:10
hi,
tou need the audio driver.
post the specs of your computer and we will give you a link where you will be able to download the driver.
thank you.
