- Sony vaio not turning on battery light flashing
- Yellow light on touchpad - Guide
- Acer keyboard light - Guide
- Solid orange battery light on asus laptop ✓ - Laptop Forum
- Sony vaio factory reset windows 7 - Laptop Forum
- Sony hard disk ✓ - Hardware Forum
5 responses
closeup22
Friday May 15, 2009
2,099
May 27, 2010 at 10:56 AM
Hi there,
There is nothing such as you described and the technician was right its an electronic issue and needs to be fixed,trying to do it yourself may cause damage if not sure and also will be cheaper than actual to get it repaired.
Why can't the battery be charged?
1.The battery has no voltage.
2.The charger has no output electric current.
3.Low charging efficiency due to external cause
Solutions to the problem:
1.Test whether the charger has voltage and output electric current or not.
2.Check if the charger is well contacted with battery.
3.Activate the battery with voltage and current 1.5 times higher than those of the battery. (Use this method only when the battery can't be charged.)
Hope your problem has been resolved. In case it still persists please get in touch with any Sony service centre near you. You can locate Sony centres here - https://locator.sony?locale=en_IN&profile=consumer/customer_support/ap
Regards,
Sony India Team.
Regards,
Sony India Team.
