- Monitor not going out of Power save!!
- Save as pdf office 2007 - Download - Other
- How to get out of power save mode - Guide
- Sceptre monitor no signal entering power save mode - Windows Forum
Hi there,
Before opting for another screen,remove the graphic card and clean it carefully specially the gold plated part by either using an eraser or some alcohol and fix it back on motherboard .
I don't have the answer, wish I did, I'd be happy to share w/ you and alot of other p@#$$ Dell owners ... If someone does have the answer, please share. I'm running Windows XP Home Edition on our Dell which is appx. 3 years old. It's had the problem from day 1 and I've not been able to do anything - can you say frustrated. I'll check this board frequently to see if anyone can help us. Good luck.
