Why won't my wireless connection work???
annie1987
5 Oct 2010 à 14:50
jack4rall Posts 6428 Registration date Sunday 6 June 2010 Status Moderator Last seen 16 July 2020 - 5 Oct 2010 à 16:22
- Why won't my wireless connection work???
- Wireless network connection - Guide
- Why won't my mp3 player connect to my computer - Guide
- Wireless network watcher - Download - Other
- Wireless personal area network - Guide
- Best wireless charger - Guide
I am using my brother's PC rite now coz he has got an internet connection which is weird, the router is downstairs and I never had a problem before. When I go to repair the connection it says cannot finish repairing connecting to the wireless network, another weird thing is that my Belkin adapter flashes green and when I've gone on network diagnostics it said something about a problem with ethernet and my wireless connection a communication problem??...That's odd because it worked at 3pm on Saturday but than didn't after i did that system restore, well it was the only way to get rid of that damn trojan.
Also on the popup next to wireless on the system tray, it has got a red cross saying not connected, I have gone on network connections as well and it has said not connected.
Sunday 6 June 2010
16 July 2020
5 Oct 2010 à 16:22
5 Oct 2010 à 16:22
Try this 1.
Click on Start --> Run --> Type devmgmt.msc and click on OK.
"Device Manager" window will be opened.
Expand "Network Adapters" or click on "+" near it.
If you notice any red cross mark, then right click on it and select "Enable".
Also check your SSID and the security key.
Good Luck.
Try this 1.
Good Luck.
