My system crashes and monitor says no signal suddnly
dingdong
Apr 5, 2011 at 03:21 AM
Aud21 Posts 36 Registration date Tuesday March 29, 2011 Status Member Last seen June 26, 2012 - Apr 6, 2011 at 03:50 PM
- My system crashes and monitor says no signal suddnly
- Signal computer - Download - Instant messaging
- Nfs carbon crashes after loading profile ✓ - Video Games Forum
- Need for speed most wanted 2005 crashes on startup ✓ - Video Games Forum
- NFS carbon second time startup crash - Video Games Forum
Miyamoto Musashi
Wednesday March 30, 2011
Apr 5, 2011 at 06:44 AM
Have you opened the side panel of your PC to ensure that the fans are functioning correctly? It may be overheating but I would expect the system to shutdown and restart.
It might also be worth checking the capacitors on the motherboard, check the following link:
http://aries.tech.officelive.com/images/fualt.jpg
Thanx for ur kind response.
The fan is working perfectly.
the system doesn't work since 4-5 hours. then it works normally for 30-45 minutes. after that it suddenly crashes and monitor says no signal. but the cpu fan functions perfectly. pls help.
Miyamoto Musashi
Apr 5, 2011 at 07:06 AM
Did you check the motherboard internally? Use the link above to look for a similar faults on similar objects on your motherboard.
Aud21
I would also expect the pc to restart like Miyamoto Musashi said. But it can be due to the type of motherboard or processor installed. Check if there is no dust that could block air from reaching the processor, in other words, clean the heatsink
