Sound device problem !
mahwish.ahsan
Saturday March 17, 2012
Mar 17, 2012 at 02:34 PM
mahwish.ahsan Posts 6 Registration date Saturday March 17, 2012 Status Member Last seen March 17, 2012 - Mar 17, 2012 at 03:02 PM
- Sound device problem !
- Blackberry device manager - Download - File management
- Try a device you’ve signed in with before yahoo - Yahoo Mail Forum
Wednesday October 8, 2008
Mar 17, 2012 at 02:50 PM
Instructions
Things You'll Need:
* Driver and Application Recovery CDs
* Updated sound driver software
Check the Speaker Connections and Volume Control Settings
1. Step 1 Verify that the lack of sound is not due to faulty speaker connections. A simple way to test it is to substitute the speaker connection with headphones and see if you get any sound.
2. Step 2 Open the volume control window by clicking your "Start" button and then "All Programs." Click "Accessories," then "Entertainment," then "Volume Control." Alternatively, just click on the speaker icon that's in your System Tray.
3. Step 3 Check the volume and mute settings. If any of the mute check boxes have been checked, uncheck them. If this doesn't work, read on.
Perform a System Restore If Necessary
4. Step 1 If the sound has been audible from your computer's speakers and is suddenly lost, you may need to perform a System Restore. Click on the " Start" button and then "All Programs."
5. Step 2 Click on "Accessories," then "System Tools," then "System Restore."
6. Step 3 Complete the System Restore Wizard. If this doesn't work, read on.
Delete and Reinstall the Original Sound Drivers
7. Step 1 Deleting and reinstalling your sound driver may resolve the problem. Your sound driver may have been corrupted or may be missing. The result of this is that the restore utility menu won't be available. For Windows XP, follow these steps.
8. Step 2 Click on your "Start" button. Click on "Control Panel" and then "System." Next, click on "Hardware," then "Device Manager, then "Sound, Video and Game Controllers."
9. Step 3 Click on a sound device named in the Device Manager, and then press the Delete key on the keyboard. Click "OK" in the window that appears. Remove all the listed sound devices i this way EXCEPT Audio Codec and Legacy Audio Drivers.
10. Step 4 Restart your computer. Reinstall the deleted drivers using the Driver and Application Recovery CDs that came with your Windows XP system.
11. Step 5 Visit your computer manufacturer's official website. Check for any updated sound driver software for your sound card. If any, download them along with the installation instructions.
Things You'll Need:
plzz suggest something else
