Internet speed is low when using idea
yash verma
Wednesday August 8, 2012
Aug 8, 2012 at 12:53 PM
ayaz - Oct 15, 2019 at 04:23 AM
- Idea internet speed
- Need for speed most wanted 2005 - Download - Racing
- Need for speed most wanted 2012 download pc uptodown - Download - Racing
- Blackmagic disk speed test windows - Download - Diagnosis and monitoring
- Intellij idea download - Download - IDE
- Download internet explorer 11 for windows 10 64-bit - Download - Browsers
Updated on Nov 30, 2018 at 04:24 PM
Speed always depend on the bandwidth that your service provider is offering to you. Airtel and Idea are two different networks. The bandwidth will differ from network to network. It also depends on how good the network coverage is.
If you are accessing internet through your mobile then delete the settings and get a new GPRS Settings. If the problem still exists then I would suggest you to contact your Idea Customer Care.
Regards
Regards
