Toshiba Satellite Pro c650 will not start...
eszaq1
Sunday March 31, 2013
Mar 31, 2013 at 02:23 PM
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 - Apr 1, 2013 at 06:03 AM
- Typingmaster pro with satellite
- Classicboy pro - Download - Console emulators
- Mp3 rocket pro - Download - Music downloads
- Pluraleyes premiere pro - Download - Video editing
- Samplitude pro x7 - Download - Musical production
- Mouse conversion pro apk - Download - Mouse and keyboard
Ambucias
11,166
Mar 31, 2013 at 05:54 PM
Dear Mark,
This my last message before I sign out for the day.
What were you doing or did before the issue occured ? Is this just out of the blue ?
How old is your lappy ?
Looks like a serious problem.
Will it start in safe mode, tapping F8 ?
Have you tried to:
1. Remove the battery
2. Remove the cable
3. Hold the power button for 58 seconds
4. Plug the cable and boot.
P.S. There has been several similar issues with Toshiba
Have you tried to:
2. Remove the cable
Ambucias
11,166
Hello Mark
This looks like a motherboard issue so a technician should be able to save your data to another disk.
Mar 31, 2013 at 06:21 PM
Thanks for your reply. In answer to your questions:
Normal web browsing, Skype, and it had never happened before.
2 years, 6 months
No, cannot get to a desktop state
Have you tried to:
1. Remove the battery - Yes
2. Remove the cable - Yes
3. Hold the power button for 58 seconds - Yes
4. Plug the cable and boot. - Yes
Do you think the harddrive and contents will be retrievable?
Thanks again, Mark
