Battery not charging
Aimal k'an
Wednesday April 3, 2013
Apr 11, 2013 at 09:57 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Apr 11, 2013 at 05:22 PM
- Battery not charging
- Ps3 controller charging time - Guide
- Battery reset code - Guide
- The system time is invalid. this may be a result of a loss in battery power ✓ - CPU & Desktop Forum
- Battery info view - Download - Diagnosis and monitoring
Apr 11, 2013 at 10:52 AM
With external supply plugged in, click on Start --> In search bar, type
devmgmt.msc and press Enter. "Device Manager" will be opened.
Expand "Batteries"--> Right-click on the "Microsoft ACPI-Complaint Control Method
Battery" --> Select "Uninstall". After uninstalling it, remove the battery from the
laptop and place it back after a while and then in device manager, click on
"Actions" --> Scan for hardware changes.
Apr 11, 2013 at 11:13 AM
I have tried this and it worked. Now its not working dunno why :(
1) After plugging your external supply, switch on your laptop and keep tapping F2 key which will take you to CMOS settings. Look at the AC Adapter type and make sure it doesn't show as unknown.
2)Make sure that your laptop is not getting overheated. Clean all the vents, blow out with canned air. Never run your laptop on bag & bed. Laptop Sides, back and bottom must be clear.
3) Go to device manager once again and update the devices that you found under batteries by right-clicking on it and selecting the option update.
4) If the problem still exists then update your BIOS.
