My External Hard drive, is having problems going on
Rika
Mar 1, 2015 at 02:17 PM
R2D2_WD Posts 3606 Registration date Monday September 1, 2014 Status Member Last seen February 20, 2017 - Mar 2, 2015 at 03:20 AM
- My External Hard drive, is having problems going on
- Whats a hard drive - Guide
- Blanco hard drive wipe - Download - Cleaning and optimization
- Lenovo external hard disk - Hard Drive & SSD Forum
- External hard drive showing as local disk - Hard Drive & SSD Forum
- Low level format hard drive - Download - Storage
Wednesday October 8, 2008
Mar 1, 2015 at 08:09 PM
Perhaps a new USB cable might fix the problem.
R2D2_WD
155
Hi there,
Is this a 2.5'' model or it is a 3.5'' with its own power cable? I strongly recommend you to change the USB cable. If the model has a power cable, change it too. Have you tried the device in all the USB ports and on another PC? This looks like a connectivity issue, but it may be related to some port malfunctioning.
Hope this helps
Hope this helps
