Laptop function key problem! please help
Thea
May 16, 2015 at 10:05 AM
xpcman Posts 19528 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - May 16, 2015 at 01:40 PM
- Laptop function key problem! please help
- Where is the insert key on a laptop - Guide
- Shortcut key for at the rate in laptop - Guide
- Hard drive function - Guide
- Mecer laptop bios key - Guide
- Mac backslash key - Guide
This is often caused by a miss-match between the physical keyboard and the logical keyboard. I suggest you go to the Keyboard icon in the Control Panel and make sure that it matches.
