I have an ASUS N76VZ tha will not power up with battery or line
STINGER11
Sunday June 7, 2015
Jun 7, 2015 at 07:12 PM
STINGER11 Posts 2 Registration date Sunday June 7, 2015 Status Member Last seen June 8, 2015 - Jun 8, 2015 at 10:07 AM
- Asus n76vz bios
- Asus fan xpert 4 download - Download - Cleaning and optimization
- Asus rog phone 8 pro - Guide
- Asus laptop volume buttons not working - Guide
- Asus recovery partition - Guide
- My asus download - Download - Cleaning and optimization
R2D2_WD
Monday September 1, 2014
155
Jun 8, 2015 at 03:51 AM
Hi Stinger11,
I would recommend you to disconnect the power cable and remove the battery. Hold the power button for 10 seconds, reconnect the power cable and try powering up. If the issue persists and the laptop has some warranty, contact the reseller. If the warranty has expired, you should contact a technician to check the laptop's motherboard and power port.
Hope this helps
Hope this helps
