- Laptop will not power with no monitor
- How to type # in laptop - Guide
- Gta 5 download apk laptop - Download - Action and adventure
- Laptop keyboard not typing letters - Guide
- Power saving mode monitor - Guide
OK, well, lets do this....with all EQ off, plug in all cables and turn on the external monitor. Make certain monitor is set to HDMI input.
Boot up laptop, pressing (not holding) F2 repeatedly until it beeps. Did you get a display, or did it shut down? If it shut down, then post back and we will go to next step. Are you good with opening up the machine? Did you already do that? If so, take out all of the ram, and boot. Does it still shut down?
Dec 11, 2018 at 05:47 PM
Dec 11, 2018 at 05:48 PM
Dec 11, 2018 at 09:31 PM
IF you get a different result when the RAM is removed, then you know the MB is good, and we can negate the possibility that the video input isn't on the correct one.
If it beeps, or flashes lights, the MB is good.......
Who was going to change out the parts?
Have FUN!
