Monitor problems
Arkon Rhys
Saturday September 19, 2009
Sep 20, 2009 at 08:33 AM
sharpman Posts 1021 Registration date Saturday May 23, 2009 Status Contributor Last seen October 20, 2010 - Sep 20, 2009 at 03:35 PM
- Monitor problems
- Monitor zoomed in - Guide
- Power saving mode monitor - Guide
4 responses
sharpman
183
Sep 20, 2009 at 08:36 AM
does it allow you to boot up to select safe mode by pressing f8?
unplug your second moniter it will return to your computer then reset your moniter as your main moniter
Arkon Rhys
Sep 20, 2009 at 01:31 PM
To Sharpman - I get the first bootup screen, it lets me select safe mode then just before it gets to the window screen, both views go blank, the view on the television and the monitor flickers a little then goes black.
To Buggfarmer - I have unplugged the TV and nothing comes up on the computer at all apart from sounds, it is very frustrating >_<
sharpman
183
ok, boot up and press f8, this time select vga mode
