Need help with a hard drive
akm7305
Thursday December 31, 2009
Jan 1, 2010 at 03:17 PM
akm7305 Posts 2 Registration date Thursday December 31, 2009 Status Member Last seen January 2, 2010 - Jan 2, 2010 at 02:08 PM
- Need help with a hard drive
- Hard drive regenerator - Download - Backup and recovery
- Working of hard disk with diagram - Guide
- Wd drive unlock - Guide
- How to install a second hard drive windows 11 - Guide
Wednesday October 8, 2008
1,826
Jan 1, 2010 at 08:01 PM
About the only way to access the drive is to remove it from the laptop and put it into an USB external hard drive adapter. You could then erase the data with a free program called Killdisk or you could use it as a backup disk for your new computer. Take the drive to a PC repair shop and they can sell you the correct adapter. They cost about $25 to $35.
