Problem with the WiFi connection DNA-A211
Amit
Oct 18, 2010 at 10:38 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Oct 18, 2010 at 11:49 AM
- Problem with the WiFi connection DNA-A211
- Rail wifi connection - Guide
- How to connect to spectrum mobile wifi - Guide
- Ps3 won't connect to wifi - PS3 & PS4 Forum
- How does wifi work - Guide
- Mac connect to wifi with qr code - Guide
Try this 1.
1) Click on Start --> Run --> type cmd and click on OK. Now enter this command
ipconfig/all and press enter.
Make sure that IP Address, Subnet Mask, Default Gateway and DNS Servers
are having addresses.
2) Right click on the "Internet Explorer" icon --> Click on "Properties" --> Click on
"Connections" tab --> Click on LAN settings button. In that window uncheck all
the options, if you notice any option selected.
3) Check your SSID and the security key also.
4) Try disabling either your firewall or antivirus temporary.
Good Luck.
Try this 1.
Good Luck.
