Need a lot of help connecting to wireless
Alex-Wilson
Saturday February 26, 2011
Feb 26, 2011 at 10:26 AM
jack4rall Posts 6428 Registration date Sunday June 6, 2010 Status Moderator Last seen July 16, 2020 - Feb 27, 2011 at 11:43 AM
- Need a lot of help connecting to wireless
- Ps3 not connecting to wifi ✓ - PS3 & PS4 Forum
- Verizon wireless activation number - Guide
- What are two cables that are used to connect a computer to a printer? (choose two.) - Network Forum
- Windows xp not connecting to internet ✓ - Network Forum
Its a wireless Lan Card that appears like TV Ariel for you. The wireless Lan card
can be used to connect to your wireless network from your desktop PC. You
need a wireless router (Access Point) to use the wireless connection.
First you have to check if the wireless is enabled or not in your router. If its
enabled then you need to know the SSID and the security key.
