Help help help its urgent ... Lost an important hidden folder
amsbeckham
Sunday December 30, 2012
Dec 30, 2012 at 03:20 PM
sam - Dec 30, 2012 at 04:23 PM
- Help help help its urgent ... Lost an important hidden folder
- Anvi folder locker reset key - Guide
- How to see hidden stories on instagram - Guide
- Lost ark download - Download - MMO
- Gmail important folder - Guide
- Hidden folder android - Guide
first let me know one thing.how did you hide your folder data? because if you know on how to hide by using properties im sure you are also have a knowlege on how to rehide it.anyway try this... first do recall on where did you hide your folder.either in desktop so stay on desktop then do open any folder, then click tools,under tools you will see the folder option,click the folder option,folder option will be appear,then click view,then mark the "show hidden files and folders uncheck the 2 box under the "SHOW HIDDEN FILES AND FOLDERS" some dialog box will appear again just click ok..... now all files that was hided will appear ...
i hope it will help to you
