Wireless Connection Problems
iJamez
Tuesday March 17, 2009
Mar 18, 2009 at 09:25 AM
iJamez Posts 5 Registration date Tuesday March 17, 2009 Status Member Last seen March 18, 2009 - Mar 18, 2009 at 10:33 AM
- Wireless Connection Problems
- Verizon wireless activation number - Guide
- Railway wi-fi connection - Guide
- F panel connection - Guide
- Ps3 internet connection failed ✓ - PS3 & PS4 Forum
5 responses
iJamez
Mar 18, 2009 at 10:07 AM
Is this the correct drivers i need?
ACER NIC-559A PRO/100+ with Alert On LAN 2
DJ AKSHAY
Sunday December 21, 2008
Mar 18, 2009 at 10:04 AM
Hi, well my friend, the driver you have got is for your LAN card and not for your Wireless LAN Card.
iJamez
Mar 18, 2009 at 10:19 AM
Yes it is
DJ AKSHAY
Mar 18, 2009 at 10:23 AM
Are you sure you have got a wireless LAN card in this PC?
See the specifications on its website on the link below:
https://www.gateway.com/worldwide/support/
iJamez
Mar 18, 2009 at 10:25 AM
I am 100% sure because i was connecting to my router fine a week ago, but after the PC restore i cant connect to anything becasue it says my wireless network adaptor isnt installed/configured.
DJ AKSHAY
Mar 18, 2009 at 10:30 AM
So you have got windows vista running. You need to enter Device Manager to check if the driver for the WLAN is installed. If not , you'll see "?" next to its name under Network.
What type of connection are you using to access the internet right now? Are you using a network cable connected to the router?
Ask a question
iJamez
When i check my device manager i see that my marvell yukon is fine, but my acer nic 559A Pro has a caution sign and is not working. And right now, im using my second computer in which a modem and the router are hooked up to.
Mar 18, 2009 at 10:14 AM
Gateway GT5465E Desktop Computer
