Wifi connection problem
Vinothkumar
Jun 11, 2015 at 04:22 PM
Jinda.hari Posts 2 Registration date Thursday June 11, 2015 Status Member Last seen June 11, 2015 - Jun 11, 2015 at 06:32 PM
- Wifi connection problem
- Rail wifi connection - Guide
- How to connect to spectrum mobile wifi - Guide
- How does wifi work - Guide
- Security or firewall might be blocking the connection ✓ - Internet & Social Networks Forum
- No internet connection pldt home prepaid wifi ✓ - WiFi Forum
OK, well websites do not disconnect. Your connection to the website disconnects. What type of router do you have? Is it your router or your ISP's? What is you Operating System? Does it drop if you are wired? Please let us know as we cannot assist you in troubleshooting your problems without these important details!
Jinda.hari
1. You can try to reset it when your in your connections.
2. Right click on the wifi and disconnect it.
3. Then find it again and doubble click on it and it will ask for a password.
It should be able to connect.
