No Signal Problem On Monitor
TheLordOfTheCraft
Wednesday November 2, 2016
Nov 2, 2016 at 09:45 AM
TheLordOfTheCraft Posts 2 Registration date Wednesday November 2, 2016 Status Member Last seen November 3, 2016 - Nov 3, 2016 at 04:32 AM
- No Signal Problem On Monitor
- Pixio monitor no signal - Monitor Forum
- Sceptre monitor no signal entering power save mode - Windows 7 Forum
- Monitor power light blinking but no display reasons ✓ - Hardware Forum
- Entering the power saving mode shortly - Windows Forum
R2D2_WD
Monday September 1, 2014
155
Nov 3, 2016 at 04:06 AM
Hi TheLordOfTheCraft,
Is this a laptop PC? So basically you were not able to use the PC for the past 6 years, right? As far as I understood, after pressing the power button, the cooling fan starts running but all you get on screen is the No Signal text.
Please try connecting your PC to another monitor or to a TV. Check if the problem persists. If so, the issue may be PC related and you may need to ask a technician for some guidance. It is hard to say where the problem comes from, but is possible that you are facing a hardware failure. If you get signal on another monitor, most probably there is a problem with your monitor of with its connections.
Hope this helps
Hope this helps
