Toshiba Satellite L555 Power problem
John
16 Apr 2018 à 15:01
SirGlahad Posts 2 Registration date Sunday 6 May 2018 Status Member Last seen 7 May 2018 - 6 May 2018 à 14:36
- Toshiba l555
- Toshiba laptop touchpad not working - Guide
- How to reboot toshiba laptop - Guide
- Toshiba laptop mouse frozen ✓ - Laptop Forum
- Toshiba laptop bios password reset software free download - Download - Other
- Toshiba Satellite mouse pad stopped working ✓ - Laptop Forum
SirGlahad
Sunday 6 May 2018
7 May 2018
6 May 2018 à 14:36
6 May 2018 à 14:36
Good day,
Seems that your laptop is having a short circuit while turning on, you can try disconnecting the important components: memories, hdd, dvd, wlan/wwan, battery, ac adapter, then press the power button for 15-20 secs.
Then try to turn on the laptop without components previously mentioned IF the laptop does the same (no display on, leds on then off) it´s a Motherboard problem, if not (it is detecting that the memories are out).
You can connect component by component while trying to turn it on to see if it´s one of them that are causing the issue.
Usually the issue is related to Motherboard.
