- Sound problems,NO sound
- Ps3 no sound - PS3 & PS4 Forum
It's better you download the driver from the motherboard support website.
You will need to know your motherboard model number,
Just open the Central Unit case and you will see the motherboard marked on the motherboard itself.
Just type on google and search
Then download the driver you want!
Jul 6, 2009 at 11:38 AM
