- Hp 620 wifi drivers
- What is wifi - Guide
- Wifi calling samsung - Guide
- Hp scanjet 2400 driver - Download - Drivers
- Hp deskjet 2050 driver - Download - Drivers
- Dell wifi drivers for windows 7 - Download - Drivers
Wednesday October 8, 2008
Feb 24, 2012 at 01:28 PM
here are many reasons a wireless radio will stop functioning. First and foremost check to ensure your wireless radio switch is turned "on"
If this is the case then ensure you have wireless network drivers installed. (right click my computer, properties, hardware, hardware manager, network adapters)
If it appears to be installed correctly, Try this, Start > Run > type in "services.msc" (without quotes) scroll down the list for "Wireless Zero Configuration" right click, check properties, in the startup ensure it says "automatic" then simply click on "start" Once it's started, right click on your wireless connection icon, select "view available wireless connections" (should still be blank) click on "change advanced settings" then "wireless network" tab and ensure the check box that says "Use windows to configure my wireless settings" is checked...
Apply and OK all and then refresh your wireless network list.
Hope this helps.
Hope this helps.
Mar 1, 2012 at 04:26 AM
