External Monitor Not Working HELP
TechnoFuz Posts 31 Registration date Wednesday 12 June 2013 Status Member Last seen 23 January 2014 - 12 Jun 2013 à 18:29
Zohaib R Posts 2368 Registration date Sunday 23 September 2012 Status Member Last seen 13 December 2018 - 18 Jun 2013 à 07:11
I am trying to connect my windows XP laptop(Home edition) to a dell monitor.The monitor is blank,but has power. I wanna extend my laptop screen to the monitor.(Having different items on each screen. ) Anyone know how to fix it?
5 responses
xpcman Posts 19528 Registration date Wednesday 8 October 2008 Status Contributor Last seen 15 June 2019 1,824
12 Jun 2013 à 19:03
The external VGA port needs to be turned on using the correct PF key. Did you try using it ?
TechnoFuz Posts 31 Registration date Wednesday 12 June 2013 Status Member Last seen 23 January 2014 1
12 Jun 2013 à 19:06
idk what that means,I have the blue plug in my laptop,my key is fn-f8,but that doesnt do anything
12 Jun 2013 à 19:18
You use the Function + F8 keys to enable the VGA port. Just hold down the "Fn" key and press the F* key with the other hand.
12 Jun 2013 à 19:20
I have tried,My monitor has power but shows nothing,its connected to my laptop.I know the monitor works cause when i disconnect the cable,monitor reads no signal
12 Jun 2013 à 19:25
You use the Intel GMA Driver icon in the Control Panel to change the "Operating Mode" to "extended Desktop". You need to have the external monitor turned on before you have this option. You then drag your icons from the laptop screen to the external monitor.
12 Jun 2013 à 19:26
I don't have that in my control panel.
12 Jun 2013 à 19:26
and my monitor wont turn on
12 Jun 2013 à 19:30
Strange - the D600 uses the Intel chipset so it should have that driver. Are you using the Windows default (VGA) video driver? If so you need to download the Interl drivers from the Dell web site.
12 Jun 2013 à 19:31
Dont know what any of that means,Im a teen,I know lots about computers and dream of being IT,but i dont know what that means
12 Jun 2013 à 19:32
how do i get to the video drivers
Zohaib R Posts 2368 Registration date Sunday 23 September 2012 Status Member Last seen 13 December 2018 69
13 Jun 2013 à 04:50
Hi TechnoFuz,
I think I can help you in this situation. Please reply with the exact System Model Number of your laptop and the exact Model Number of your Dell Monitor, so that I can look for the appropriate settings and help you.
To know more about Dell's products, services and drivers & downloads, please go to http://dell.to/YBlak6
15 Jun 2013 à 15:25
I have No Idea
18 Jun 2013 à 07:11
Hi TechnoFuz,
You can find Dell Monitor's Model Number by pressing the menu button on the monitor. After pressing the menu button on the Dell monitor the first line indicates the Dell Monitor's Model Number for example, Dell 1708FP. For the laptop's model number please refer to the documentation or manuals of the laptop.
