Dell 610 battery led's not lighting up, computer wont start
buck63
Thursday October 10, 2013
Oct 10, 2013 at 09:12 PM
Zohaib R Posts 2368 Registration date Sunday September 23, 2012 Status Member Last seen December 13, 2018 - Oct 14, 2013 at 10:41 PM
- Dell 610 battery led's not lighting up, computer wont start
- Battery reset code - Guide
- Start 11 download - Download - Customization
- Start survey online free - Download - Horror
- Perfection 610 treiber - Download - Drivers
69
Oct 11, 2013 at 06:47 PM
Hi buck63,
Let's try the below mentioned steps to isolate the point of failure:
1. Disconnect all peripherals and confirm if system is working fine with AC Adapter only. If no, the problem is not the battery.
2. Remove AC adapter, Battery and drain flea power by pressing and hold the power button for 10-15 seconds. Re-connect only the AC Adapter and check if the computer powers on.
3. Check the keyboard status lights. If keyboard status lights are lit in a sequence this indicates a system problem. Please reply with the sequence of light you observe.
Please do write back to us.
To know more about Dell Product Support, Drivers & Downloads, Order & Dispatch status -> choose your region US Customers; India Customers. For Dell support videos click Here.
ok i did all that and does same thing all the way around it comes on for a second and shuts off again, and all the lights come on green and then shut off, no blinking!
69
Hi buck63,
The most probable cause of the problem can be detected by removing few of the components from the computer and then trying to place them back one by one. Remove the components in the following order and try to power on the computer with the part removed one-by-one:
1. AC Adapter (with the AC Adapter disconnected try to power on the computer with Battery only)
2. Battery (with the Battery removed power on the computer using AC Adapter only)
3. Keyboard
4. Hard Drive
5. Ruggedized Hard Drive (if any)
6. System Memory
7. Mini PCI
8. Bluetooth Card
9. Modem Daughter Card
10. Optical Drive
If you are able to identify the point of failure during removal (and then powering on) of any of the components listed above, you can consider it as the point of failure. If the computer still doesn't power on, the problem is with the Motherboard or some other internal components. For the latter case you will need to have your computer serviced by a technician. You will find the steps for removal of the parts listed above in the Service Manual.
Do reply with results.
3. Keyboard
4. Hard Drive
6. System Memory
7. Mini PCI
8. Bluetooth Card
10. Optical Drive
