- Problem with sound device not play media file
- Play store zip file download - Download - App downloads
- Media player 12 - Download - Audio playback
- Windows 10 iso file download 64-bit - Download - Windows
ungivepc
Wednesday October 1, 2008
4
May 12, 2009 at 05:01 AM
hi,
you need to install the sound driver.
please post the full details about your computer and we will give you the link where you can download the driver.
Hi! Did you recently uninstall BearShare or other programs like it? Try Uninstalling the Device and Re installing it again. Here's how:
Start Button
RIGHT click "My Computer"
Properties then the "Hardware" tab
Device Manager
Go down and expand [+] the Sound, video and game
If there's a yellow question mark(?) in one of the devices, RIGHT click on it and then "Uninstall" You'll get it back, don't worry.
Click Start again
Control Panel
Add Hardware. This will find the device you just uninstalled. Click on the one you JUST deleted and then Next.
It should be re-installed now. Go back to your Control Panel and then Sound and Audio. Play around with the speaker settings and see if that helped you....
Alternatively, you can use System Restore to restore your computer settings to a certain day, maybe the day before you installed a certain program which deleted your sound settings...? That's if that's what caused it in the first place
Best of luck!
Start Button
Device Manager
Click Start again
Control Panel
Best of luck!
Aug 10, 2009 at 11:31 AM
model:js555
its a multimedia computer system
