How to connect 2 systems using LAN
- How to connect two computers using lan cable in windows 7 and windows 10
- Write steps to connect the computer in lan - Best answers
- 192.168 1.568 - Best answers
- Kmspico windows 10 - Download - Other
- Windows 10 download 64-bit - Download - Windows
- Gta 5 download apk pc windows 10 - Download - Action and adventure
- Bandlab download for pc windows 10 - Download - Musical production
- Blackmagic disk speed test windows - Download - Diagnosis and monitoring
11 responses
Hello friend,
I read your massage, I known what your problem is.
1st step: you have a cable his name is TIA/EIA 568-B.2 CATEGORY 5e and RJ45 connector
2nd step: make a cross cable
1st point 2nd point of cable wires
1--------3
2--------6
3--------1
4--------4
5--------5
6--------2
7--------7
8--------8
Cable each wires setting.
3rd step : install Ethernet hardware
Right click "my computer"
Move mouse "computer properties"
Click "hardware" tab menu
Click "Device Manager"
Device manager window is open
Check network adapter
"PCI Fast Ethernet NIC" is work or not?
If NIC device is work then do next work
Else Nick device have cross simple then double click NIC device.
And "Enable Device"
Device usage: use this device (enable)
4th step. Create a ip address to both system are not same (My network places)
So I hope you are understand my simple language.
1--------3
2--------6
3--------1
4--------4
5--------5
6--------2
7--------7
8--------8
And "Enable Device"
- Click: - "view network connections" in network tasks
- Right click: - local area connection
- Ex: Realtek RTL8139 family PCI
- Click: properties
- Click 'this connection uses the following item:'
- Internet protocol (TCP/IP) click "properties"
- Use the following IP address
- Ex: -
1st PC 192.168.0.100
Subnet mask 255.255.255.0
2nd Pc 192.168.0.200
- 5th step: dos command check connection
- Ping ip address (other pc)
- Ex:
ping 192.168.0.100
- They have checking connection
- And message report
- 6.click in network task Firwall setting change Off (not recommended) both system.
- 7-check group are same in my computer properties "computer Name" Ex: "workgroup"
- 8. Then plug in cable to computer pc1 pc2.
- Then message is display "network cable is plugging with 100mbps"
- Then click "network placese" and click "view workgroup computer"
Oct 6, 2008 at 01:06 AM
I read your ans iget every thing. but I didn't internet please give me ans my mail
THANK YOU
Oct 14, 2008 at 06:25 AM
I read your massage, I known what's you have problem.
About me: -
Name - jitendra Kumar Sharma
From - India (Bihar) muzaffarpur
I am student of BCA 5 SEM.
Ok
Your question is how to connect 2 system using LAN?
Ands is: -
1 step: - you have a cable his name is
And RJ45 connector
2step: - make a cross cable
1--------3
2--------6
3--------1
4--------4
5--------5
6--------2
7--------7
8--------8
3 steps: your computer have install Ethernet hardware
How to
And "Enable Device"
End work
next
4 steps. Create a ip address to both system are not same (My network places)
Click: properties
Ex: -
Click "ok" "ok"
4 steps: dos command check connection
Ex: ping 192.168.0.100
And massage report
5.click in network task Firwall setting change
6-check group are same in my computer properties "computer Name"
Ex: "workgroup"
7. Then plug in cable to computer pc1 pc2.
Then massage is display "network cable is plugging with 100mbps"
Note:
Windows Xp any new
1.568 cable is make in cross 1---3,2----6,3----1,6-----2
2.same work group name
3.if you have problem to generate to ip address so this is not important to computer because automatically assign ip address
4.if Ethernet is not work/ not install
You have installed it with "main board" cd
Insert cd in cd Rom click "my computer" "properties" "hardware" "device manager"
Right click NIC device and choose update device click next to fowling instruction.
5.firwall setting, anti viruse firewall setting.
6. Ms dos command ping is must be using.
Ping command using in dos
If massage is Request timed out.
So you have a cable problem.
Of work group problem.
