Problem with WLAN connection
frogpuppet
Wednesday June 30, 2010
Jun 30, 2010 at 10:19 PM
xpcman Posts 19530 Registration date Wednesday October 8, 2008 Status Contributor Last seen June 15, 2019 - Jun 30, 2010 at 10:33 PM
- Problem with WLAN connection
- Railway wi-fi connection - Guide
- F panel connection - Guide
- Steam no connection - Guide
- Connection lost facebook ✓ - Facebook Forum
- Playstation.com/connection ✓ - PS3 & PS4 Forum
1,826
You might try to unplug the power supply and wait 15 minutes before connecting it again. This might clear the problem.
The next step is to reset the router to factory defaults. This is normally done using the reset switch found in a hole on the back of the router. You will then need to do the router set-up again.
The last step is to contact the manufacturer for replacement.
