No display,,,No booting but power indicator is still Running
Ask a question jayprasad - Latest answer on Sep 17, 2016 02:22PM
i'm jayprasad,,,,my Dell vostro 2520 and Imprion N4050 both laptop are same problem,
last time i update a OS and i installed the system compatable drivers,,finaly i installed the BIOS update,when suddenly off my laptop,,,then i'm turn on the system,but only the power indicator still running,,,no dispaly ,,,no booting ,,laptop screen is giving the blank screen,,,,plz help me,,,,give the solution,,,,send me the solution in my ***@***
sry for my bad ENGLISH,,,plese help me.......
+0
moins plus
It is obvious that you don't know what your doing when you do BIOS updates. A failed BIOS update will make the computer useless until you can replace the BIOS chip with a correctly programmed unit.
I suggest you never do a BIOS update again. Unless you have identified a specific major problem a BIOS update is rarely of any benefit.
Good Luck with you next computer
Add comment
Members get more answers than anonymous users.
Being a member gives you detailed monitoring of your requests.
Being a member gives you additional options.
Not a member yet?
sign-up, it takes less than a minute and it's free!
