Samsung laptop power and battery lights flashing
Kaput - 5 Apr 2018 à 13:47
 Blocked Profile - 5 Apr 2018 à 20:54
Hi everyone
Many similar posts but in my case both lights are blinking and the computer doesn't even start anymore
Just before that the computer was working perfectly
Then the battery discharged and wouldn't charge anymore
Then the computer switched off and when I tried to power it only the battery light was blinking orange
I managed to start it one last time with ctrl fn Dell f2 (whatever this is) but 2 min later it switched off and I ha ve now both lights blinking and no start
Samsung NP905s3g
And yes I have tried all the troubleshooting stuff and nothing worked
Any idea why the error changed? Motherboard? Battery connector?
Thanks for your help!
5 Apr 2018 à 20:54
If...
"And yes I have tried all the troubleshooting stuff and nothing worked"
Then...
You have tried it all!
Else,... buy a new one! Get a local technician, or the ones who you buy your new one from, to take the data off the other HDD!
Have fun!
