- HElp ipod problem D=!
- Ipod white screen ✓ - Monitor Forum
- Transfer music from ipod to computer - Guide
- How to put music on ipod without itunes - iPad, iPod & iPod Touch Forum
- Ipod touch apple logo appears then disappears ✓ - iPad, iPod & iPod Touch Forum
- Ipod won't turn on ✓ - iPad, iPod & iPod Touch Forum
Please firstly check whether the charger that you are using is not damaged.
If it isn't damaged, please consider resetting the iPod please through the below
provided steps:
https://support.apple.com/en-us/HT204307
If ever the reset doesn't solve the matter, then it may be concluded that the
problem could be with the battery and you should have it replaced.
Thanks in advance.
provided steps:
Thanks in advance.
