No sound... help
Sagg
Oct 27, 2008 at 05:52 AM
jmp59 Posts 29286 Registration date Tuesday June 8, 2004 Status Contributor Last seen November 25, 2015 - Oct 27, 2008 at 01:17 PM
- No sound... help
- Ps3 no sound - PS3 & PS4 Forum
rubrami281
Tuesday September 30, 2008
104
Oct 27, 2008 at 12:58 PM
Go to start>>>>>>>>>control panel>>>>>>click on Realtek sound effects. When prompt........click on audio l/O.........in the Analog box click on back panel LR next to BLUE icon......... a window will open, "which device did you plug in?"....make sure there's a check mark next to front speaker out. Do the same for GREEN panel LR. C if this works for U............Good Luck!!!!!!!
jmp59
249
An other way http://ccm.net/forum/affich 6703 installing audio device?page=2#37
Post 35 by goober_2005.
