Monitor no signal, won't stay connected
benj4n
Oct 16, 2010 at 05:07 PM
Ambucias Posts 47312 Registration date Monday February 1, 2010 Status Moderator Last seen March 28, 2026 - Oct 17, 2010 at 04:23 AM
- Lg monitor no signal entering power saving mode shortly
- Arzopa portable monitor power saving mode ✓ - Hardware Forum
- Entering the power saving mode shortly ✓ - Monitor Forum
- Sceptre monitor no signal entering power save mode - Windows Forum
- How to turn off power saving mode - Guide
- Lg monitor power saving mode - Monitor Forum
Ambucias
11,166
Oct 16, 2010 at 05:36 PM
Greetings Ben,
The first part of the diagnostic is to determine if the problem comes from your monitor or from your graphic card or your cable connection.
First check your cable connection.
If possible, try to borrow a monitor which is in good working order to plug in your CPU. If you experience the same problem, the problem may come from your graphic/video card which may need to be cleaned or replaced.
Oct 16, 2010 at 08:47 PM
I tried another monitor and its the same thing. It will work up until the windows xp screen comes on and then the monitor turns off. the computer itself still makes noises but nothing id displaed on the screen.
