- Lenovo laptop charging light blinking but not charging
- Acer laptop keyboard light - Guide
- Lenovo laptop hard disk not detected ✓ - Hard Drive & SSD Forum
- Esc f1 f4 blinking lenovo ✓ - Laptop Forum
- Toshiba external hard drive blinking blue light - Hard Drive & SSD Forum
- Lenovo laptop won't turn on ✓ - Hardware Forum
Anonymous User
1 Jan 2011 à 07:37
1 Jan 2011 à 07:37
Unplug the power --> remove the battery --> Hold the power button for 60
seconds --> Connect the power supply then try to switch ON the laptop and later
put the battery back into the laptop.
Good Luck!
Good Luck!
1 Jan 2011 à 08:35
May I ask, what does the blinking of both lights mean? How does your comment explain that the blinking will stop? What is the explanation behind the blinking?
1 Jan 2011 à 09:59
It can be the processor, the ram or the graphic card in the motherboard. Usually this is an internal problem. But I can't tell you exactly the problem.
2 Jan 2011 à 01:10
2 Jan 2011 à 09:37
1) When you switch ON your computer, start tapping the "F8" key to get
"Windows Advanced Options"( if boot menu appears, press "Esc" key and keep
tapping the F8 key)
2) Select "Safe Mode"
3) Go to Control Panel -> Backup and Restore -> Recover system settings or your computer -> Open System Restore -> follow the wizard to restore the system to the state before the issue occurred
7 Jan 2011 à 08:08
i got this laptop 3 years ago btw
