My monitor will not power on after turning on
Razzadas
Saturday July 28, 2012
Jul 28, 2012 at 01:06 AM
Razzadas Posts 2 Registration date Saturday July 28, 2012 Status Member Last seen July 28, 2012 - Jul 28, 2012 at 06:31 PM
- My monitor will not power on after turning on
- Acer will not power up ✓ - Laptop Forum
- Lg flatron monitor not turning on ✓ - Monitor Forum
Jul 28, 2012 at 02:31 AM
If you notice that your CPU fan is running but there is no display in the screen,
then remove the RAM from the slot, clean it and place it back properly or try
another slot. Check your RAM also. Even bad RAM will result in display problem.
Razzadas
Hi Mate
Hey, all to easy, I did what you suggested about removing ram and cleaning, I also used another ram jack and all is good.
Great work and thankyou very much.
Razzadas
Razzadas
