- Help, no signal to monitor + no beep
- Pixio monitor no signal - Monitor Forum
- Sceptre monitor no signal entering power save mode - Hardware Forum
- D sub no signal ✓ - Monitor Forum
- Secondary monitor stays in power save mode - Windows 7 Forum
Hi there,
Problem is frequency as you mentioned old one was pc -5300 and new new 6400,you need to change it back and take same frequency,use cpuz which will give you the amount of maximum of ram which can be added on your system,here is the free download link:
https://ccm.net/downloads/security-and-maintenance/4993-cpu-z/
