Help! Volume does not contain a recognized fi [Closed]
Ask a question sabik13 1Posts Saturday September 11, 2010Registration date September 11, 2010 Last seen - Last answered on Sep 11, 2010 10:39AM by jack4rall
My external hard drive was working since I got it and I stored my work in it. today,I just plugged in my external harddrive will all my work!!!! to my computer and it said:
"Volume does not contain a recognized file system Please make sure that all required file system drivers are loaded and that the volume is not corrupt?
WHAT CAN I DO!!??! CAN I RECOVER THE FILES?? THANK YOU!
Additional Details
When I attemp to access, it says I have to format it...BUT IT HAS MY WORK...:'(
+48
moins plus
Try this 1.
Right-click on your external drive --> Properties. If the "File System" is RAW, then
may be partition got damaged or corrupted.
Click on the below link and download the file.
http://download.cnet.com/...
Select the option "Damaged Partition Recovery". It will try to recover the data
from the damaged partition.
Good Luck.
Not a member yet?
