Vaio sound problems!
- Sony vaio sound not working
- Sony vaio bios key - BIOS Forum
- Ps3 sound not working ✓ - PS3 & PS4 Forum
- Vlc sound not working ✓ - Video software Forum
- Sony hard disk ✓ - Hardware Forum
4 responses
karenmen
Saturday August 29, 2009
Aug 30, 2009 at 10:35 AM
Don't worry for that, I had the same problem as your and I found the solution.
Try to uninstall your current driver and install the last version of your driver. After uninstalling the driver and reboot it to automatically reinstall it, the audio still may not work. Amazingly though, sometimes after putting the system in hibernate mode and coming back, the audio worked.
If it doesn't work, go to noaudiooutput.com, they have many suggestions. I found my solution there.
Hope it helps
Hope it helps
Jan 8, 2010 at 08:24 PM
Apr 13, 2010 at 10:08 PM
