- Wireless Internet Connection Problem
- Wireless network connection - Guide
- Wireless network watcher - Download - Other
- Cannot open web pages but internet connected ✓ - Internet & Social Networks Forum
- Download internet explorer 11 for windows 10 64-bit - Download - Browsers
- Wireless personal area network - Guide
Anonymous User
Dec 27, 2011 at 01:15 PM
I assume you have the message "Limited Connection".
Ok, follow these steps and see if it will solve the issue.
Try to connect again then right click on the network icon on the bottom right of the
screen and click diagnose repair. Click on the option to check Tcp/ip settings. Follow
those directions for the IPversion4. You will be able to connect after that.
The main idea is that the laptop wasn't getting an ip address automatically, and that's what you're going to change in the IP settings.
Best of luck, if it works for you, spread the word!
Dec 27, 2011 at 01:23 PM
Dec 27, 2011 at 01:32 PM
Try to uninstall your network driver, go to your computer official website and download the lan and wireless latest driver then re-install it to see if it will solve the issue.
