Sony Vaio not running many webpages
tyman502
Monday August 18, 2008
Aug 18, 2008 at 06:08 PM
xino - Aug 27, 2008 at 05:12 AM
- Sony Vaio not running many webpages
- Sony vaio factory reset alt + f10 not working - System software Forum
- Sony xperia hard reset - Guide
- Internet connected but webpages won't load ✓ - WiFi Forum
- Connected to internet but web pages won't load ✓ - Network Forum
4 responses
https://www.majorgeeks.com/files/details/atf_cleaner.html
use this program ATF-Cleaner
no need to install, just add it to your desktop.
Tick every box except for saved password and click on Empty selected.
Click on Firefox and Opera section and do the same as above
The Opera section wasn't selectable because you don't have it installed.
Install this software Zone Alarm. What ever software/program tries to run, it will notify you first if you should allow it or block it.
Try and install it, I hope it installs on Vista.
Install this browser Maxthon.
Because FireFox and Opera are considered to be the best internet browser.
Maxthon works like FireFox.
tyman502
Aug 26, 2008 at 05:47 PM
Unfortunately Zone Alarm is not Vista compatible. I also installed Opera and tried to use it, many sites are still saying unable to open!
:/ I knew it
Instead of Opera
try Maxton, it works like FireFox
You can also try Advant
There is a program that works like ZoneAlarm, I know it's a McAfee software, but I kind remember what package it's called. You will have to download a McAfee software and find out.
I think its called McAfee Internet Security Suite
Instead of Opera
tyman502
Aug 25, 2008 at 01:47 PM
Hey i got to the major geeks site and did as stated above, although the Opera section was not available to clear out. It wasn't highlighted or anything so i couldn't clean it out. I tried to run ad-aware update but it said i need to connect to the internet which i already am. Also the problem wasn't revolved i still get unable to open website and server not found page! Any other suggestions?
